pietpetoors
My Yamaha R-N602 switches itself off. It is intermittent, thus difficult to find the problem. Took it to a repairer a while ago and they said nothing wrong. Got it back, was fine for 3 weeks, then started again. Now I cannot even listen to one track then it switches off.
Error log says it is loss of power.
I checked solders on power relays and I checked connections, still the same. That is as far as my electronic knowledge goes.
When you switch power button on you will hear soft click of relay. After 5 seconds you will hear a louder click of another relay. If you switch off with remote you also hear the louder relay click. Switch on with remote, you hear soft click and 5 seconds later the loud click.
Now when it switches off by itself it is the louder relay I hear clicking. When it switch off by itself the reaction is exactly the same as when you switch it off with the remote.
Seems many Yamaha users with different devices have the same issue. I did update the firmware to the latest as this is one of the possible causes I read so far.
